It is currently Wed Jun 11, 2025 6:22 am
 Post subject: Burnisher idea.
PostPosted: Tue Feb 26, 2013 8:11 pm
Sent from my GT-P3113 using Tapatalk 2
Under Compensated Nut!
 Post subject: Re: Burnisher idea.
PostPosted: Tue Feb 26, 2013 8:13 pm
Here's a link to a burnisher idea from a friend of mine.
https://www.youtube.com/watch?v=-EnhuGN ... ata_player
PostPosted: Wed Feb 27, 2013 10:21 pm
First name: matt
Last Name: zimbelman
City: Durham
Zip/Postal Code: 27705
Thanks for the tip. [:Y:]
http://www.unit5woodworks.com
PostPosted: Thu Feb 28, 2013 9:26 am
First name: Mark
Last Name: King
City: Vacaville
Zip/Postal Code: 95688
That's a great idea. What did he call that, an iteration bearing?
PostPosted: Fri Mar 01, 2013 1:21 pm
Actually it's the inner part ( I think he called it 'race') of a snowmobile bearing. Any bearing should do, roller type that is. He smashed the outer part to break the bearing apart, but an angle grinder could quickly separate the two parts. Bet your friendly auto fixer has lots of used bearings.
PostPosted: Fri Mar 01, 2013 7:03 pm
First name: David
Last Name: Eddy
City: Mandeville
State: La
Zip/Postal Code: 70448
Great idea! Both sides at the same time, I like it!!
I might grind that shape in an old drills shaft.
PostPosted: Sun Mar 31, 2013 2:03 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
Looks like an accident waiting to happen. A better idea would be to clamp the bearing in the vise...Mike
PostPosted: Sun Mar 31, 2013 8:19 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
+ 1 on the clamp in vice for safety. Any ball bearing would do but a large one would be easier to clamp in the vice.
Fred
Fred Tellier
PostPosted: Wed Jun 05, 2013 1:14 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
What Fred said... Ball bearing, not roller bearing. Cool idea!
PostPosted: Wed Jun 05, 2013 8:39 pm
First name: Nelson
Last Name: Palen
Looks like the cross section radius of the ball path would effect the shape of the burr by taking it a little past 90 degrees to the scrapers edge. Also, the diameter of the bearing might influence how hard the scraper must be pressed against the bearing. Just thinking about what's happening during the process--not trying to complicate it.
Great idea!
PostPosted: Mon Jun 17, 2013 4:30 am
Yeah, I meant ball bearing, not roller bearing.
Sent from my GT-P3113 using Tapatalk 4 Beta
